I’m wondering if someone would help me diagnose a metering problem.
Recently I seem to be underexposing and I’m trying to figure out what I’m doing wrong. I used to just take a stab at what the mid-tone should be but to take more control I decided to try averaging the darkest and lightest areas that I want to retain detail in.
The scene below is a case in point, the first thing I did was meter the highlights in the foreground and the sky, this indicated a .6 GND was needed and looking at the balance in the slide that part seems to have been about right.
Now the problem, for the foreground I metered a spot in the shadows and the brightest foreground highlight and took an average (circled areas in the image below), which worked out as 1 second @ F/29, unfortunately I didn’t make a note of the range but If I remember correctly it was approximately 1.5 stops above and below the average reading.
The resulting slide (raw scan from Silverfast) is shown below along with a snapshot of it's histogram. I would guess that it’s under exposed by at least 1.5 stops, maybe 2.
Film used was RVP50, expired 08/11 but kept in the fridge, could this be the culprit? I took A and B shots, one developed at home, the other (the one shown here) developed by Peak Imaging (this was part of a test to check my developing times are right, the one developed at home did turn out a bit brighter which I took to indicate my first dev time was a bit too long, but that's a discussion for another day
Do you think my metering technique is flawed or should I be looking elsewhere for the problem?
Paul.
P.S.
I wouldn't rule out user error, it's quite possible that I suffered some kind of brain freeze and made a dumb mistake but I took 6 shots on the evening in question and they all suffered from the same problem to varying degrees.
