JetTec inks - UPDATE
Post by dennis » Tue Jul 14, 2009 9:57 am Etc/GMT-1+01:00
Does anyone have any experience of using JetTec inks in an Epson Stylus Photo printer? I have just discovered that Epson inks for my R800 now cost in excess of £16 per colour - that's over £1600 per litre! Surely a rip-off? Thanks. :(
Update: I have gone for the proper Epson cartridges, but from Premier Ink rather than Epson - about £3.00 less for each cartridge & first class post for 99p. Ordered Monday, arrived Tuesday. First time I have used this firm, but probably not the last. Dennis.
Last edited by dennis on Wed Jul 29, 2009 11:23 am Etc/GMT-1+01:00, edited 1 time in total.
Re: JetTec inks
Post by Joanna Carter » Tue Jul 14, 2009 10:30 am Etc/GMT-1+01:00
Fotospeed do an excellent continuous ink system for the R800, complete with 65ml (about 5 cartridges worth) of each the 8 inks. With dye inks, the system costs £97.86 and £9.78 for each 100ml refill bottle; with pigment inks, the system costs £161.48 and £24.46 for each 125ml refill bottle. So pigment ink works out at only £195.68 per litre :) If longevity isn't any issue then the dye inks work out at only£99.78 per litre.
I use the Fotospeed CIS, with pigment inks, on my Epson R2400 and can vouch for the print quality and lack or nozzle blocking. the only precaution I take against blocking is to leave the printer switched on 24/7; but I think that could be cheaper than paying Epson's ink costs.
DJ
Site Admin
Re: JetTec inks
Post by DJ » Tue Jul 14, 2009 11:06 am Etc/GMT-1+01:00
WIth regard to leaving the printer on 24/7, this will only help prevent nozzle clogging on Canon or HP printers, as these use thermal heads. Epsons use piezo electric heads which are "parked" in a capping station when the printer is turned off, so you should turn it off when you've finished using it.
They're two very different head technologies, the thermal bubblejet heads come with many "spare" nozzles, and are designed to be replaceable parts. When a nozzle become badly clogged, it is disabled and replaced by one of the spare nozzles. When you run out of "spares" you have to buy a new head. This is why is so important not to let those get clogged, and why they are left on, as they will periodically run a head clean even when not in use.
The piezo electric heads on Epson use electricity to fire the ink, and have the exact number of nozzles needed, and are designed to be cleanable and last the lifetime of the printer. These machines won't run cleaning cycles when left idle, so you should turn them off to ensure the head is properly capped.
As for ink costs... don't get me started. Epson have just increased their costs again a month or two ago by 10%, second rise this year. At least with the large format printers the bulk ink cost is much lower, but still... the cost of 110ml carts for my 4000 has nearly doubled since I bought it.
The new Epson 7900 takes 350ml cartridges, 11 of them, a full set of ink costs £1160! Kind of makes me glad I can't afford one ;)
Re: JetTec inks
Post by Joanna Carter » Tue Jul 14, 2009 11:37 am Etc/GMT-1+01:00
DJ wrote:WIth regard to leaving the printer on 24/7, this will only help prevent nozzle clogging on Canon or HP printers, as these use thermal heads. Epsons use piezo electric heads which are "parked" in a capping station when the printer is turned off, so you should turn it off when you've finished using it.
Hi DJ. Well whatever the technology, I have found that I get less damaging clogs by leaving the printer on. I used to turn it off and this simply meant that 1. the jets clogged more often, especially when left for an extended period and 2. it would run a cleaning cycle whenever I turned it back on, thus wasting precious ink.
Re: JetTec inks
Post by dennis » Wed Jul 15, 2009 11:05 am Etc/GMT-1+01:00
Joanna,
Thanks, but I'm not sure I use enough to warrant the continuous flow type system. I just can't help feeling that the Epson 'own brand' are something of a rip-off. Dennis.
Re: JetTec inks
Post by Joanna Carter » Wed Jul 15, 2009 11:18 am Etc/GMT-1+01:00
dennis wrote:Thanks, but I'm not sure I use enough to warrant the continuous flow type system. I just can't help feeling that the Epson 'own brand' are something of a rip-off
I suppose it comes down to who do you trust to provide ink that won't mess up the print head. I know nothing about the JetTec inks but I have a lot of experience with the Fotospeed ones. Although I would take a look at the guarantee that JetTec give; it is very cleverly worded :
If for any reason the situation arises whereby it is claimed that a Jet Tec product has damaged the printer, the following shall apply. Jet Tec guarantees that, in normal use its products will not cause damage or abnormal wear when used in printers in which they are designed to operate. Jet Tec shall not be liable to the buyer if any damage or abnormal wear to a printer that is claimed to have been caused by use of a Jet Tec product, could have been caused by goods not supplied by Jet Tec used in the printer before or after the use of a Jet Tec product.
So, if you have used Epson ink before fitting theirs and the print head fails after fitting their inks, they absolve themselves of responsibility :?
However, if you didn't check the printer was working before fitting the JetTec inks, then Epson would tell you that they cannot be held liable for the use of unauthorised products and that you would have to prove it was not the JetTec inks that caused the failure.
Re: JetTec inks
Post by dennis » Thu Jul 16, 2009 8:51 am Etc/GMT-1+01:00
Joanna
Yes - that is the problem. My wife tends toward the view that you get what you pay for & if I want Epson quality I should pay Epson prices. Oh what a dilemma! I'll have a look at the Fotospeed site. Thanks anyway. Dennis
Re: JetTec inks
Post by dennis » Thu Jul 16, 2009 10:15 am Etc/GMT-1+01:00
Joanna,
Just been browsing Fotospeed & Lyson sites & find that Lyson suggest switching the printer (Epson) on every few days because when it is switched on it does mini head cleaning process. The Lyson ink system for R800 is not continuous tho, only larger, refill cartridges - more options! Dennis.
Re: JetTec inks
Post by Joanna Carter » Thu Jul 16, 2009 10:50 am Etc/GMT-1+01:00
dennis wrote:Joanna,
Running a head clean (Epson don't seem to understand "mini") can consume a fair amount of ink so I am not surprised that Lyson suggest their strategy :wink: . You need to weigh up whether you feel leaving the printer switched on 24/7 costs more than the volume of ink used every time you switch the printer on "every few days".
Even though I leave my R2400 on 24/7, I still need to check for any potential nozzle blockages before wasting an expensive sheet of paper. So I use the printer utility to run the automatic check and clean cycle. This has the advantage of making the nozzles work harder to print the larger test pattern but it only seems to clean those colours that it detects have not printed correctly. In my experience, this uses less ink than the standard cleaning routine.
Lyson seem to have a good name but do remember that refillable cartridges are only good for so many refills; Lyson only seem to recommend using them for the amount of ink in the refill bottle.
To start with the Lyson system, you would have to spend £46 for the cartridges and £138 for a set of 60ml bottles; total £184 compared to the Fotospeed CIS system with 65ml inks for £161.48. What's more, with a CIS, you don't have the messing around of having to access the cartridges, either in or out of the printer, to top up the ink reservoirs.
But, the choice is up to you :D
DJ
Site Admin
Re: JetTec inks
Post by DJ » Thu Jul 16, 2009 12:54 pm Etc/GMT-1+01:00
dennis wrote:My wife tends toward the view that you get what you pay for & if I want Epson quality I should pay Epson prices.
There's probably a great deal of truth in this. Epson ink prices are horrendous, but IMHO their ink is unsurpassed in quality (at least on Epson's printers), let's face it, the sheer quality of inkjet printing we enjoy today is only due to the innovations of Epson who have basically revolutionised inkjet photo printing, Canon and HP were only playing catchup until just recently. Interestingly, on my paper of choice the HP pigment inks are the longest lasting by a country mile!
I personally wouldn't consider buying third party inks for my printer and not because I was afraid of damaging the head, but because I believe the OEM inks are better. The reason for this I believe is that they spend millions and millions on research and development just on ink, they're a huge company and can afford and justify doing so. Smaller companies like Lyson and Fotospeed et al have a far more limited ability in that respect. This doesn't mean I would consider their product poor quality, quite the contrary, but I do not believe them to be at the level of Epson and the other OEMs.
How close are they? That's the problem, we've no way of knowing, any evaluation is subjective as there are still no standardised tests. The closest we have is the excellent work of Henry Wilhelm and his institute (WIR), who perform independent longevity testing and have pioneered most of the methods of evaluating that kind of thing, most of which are now being converted into an ISO standard so these things can be reliability evaluated. Interestingly the OEMs (Epson, Canon, HP) have their inks tested by WIR (whether voluntarily or otherwise), and yet the third parties like Lyson and Fotospeed do not, this worries me. Have they something to hide? If their inks were as good as they claim surely they would submit them, the results from such tests would be a real feather in their cap. Oh and whilst I'm on the subject, be very skeptical of anything Kodak claim... :wink:
Lyson, to their credit, do perform testing based on Wilhelm's methods, and they do publish those results, but they perform the testing themselves rather than by an independent body, and the results aren't really complete, their flagship pigment ink product is not included in the results, why?
Fotospeed claim 85 years permanence on their website, yet give absolutely no details whatsoever about how this figure was obtained, or any technical data on their inks at all. Suspicious.
Jet-Tec don't do pigment inks at all anymore, they only do dyes which don't have the same longevity as pigment, and on their website explain why they're not going to do the testing that other ink makers use because they found some lab in Germany which said they didn't need to. Very worrying.
To illustrate the huge discrepancy between OEM and third party inks ( albeit not high quality 3rd parties like Lyson etc ), an excerpt from a WIR test, using the same model printer, and on the same high quality paper :
  • HP OEM ink - 73 years
    Tesco ink - 0.9 years
    Jessops ink - 4.5 years
    "Ink Tec" ink - 2.3 years
I personally would be wary of any 3rd party products, if I had to have a CIS I'd look at Lyson over the others because at least they do the testing and publish the results, but that's just me, and I fully admit to being very geeky about printing... :D
Re: JetTec inks
Post by Joanna Carter » Thu Jul 16, 2009 1:30 pm Etc/GMT-1+01:00
DJ wrote:if I had to have a CIS I'd look at Lyson over the others because at least they do the testing and publish the results,
Unfortunately, Lyson don't do a CIS for the R800, only refillable cartridges.
DJ wrote:but that's just me, and I fully admit to being very geeky about printing... :D
If it weren't for geeks like you, the world would be a much poorer place :roll:
