Why are dark cloths red and black
Hi
I have 2 dark cloths which are both black and red
they come from differnt places and are of different construction
Anybody know what the differnt colours are for ?
Robin
Robin
Re: Why are dark cloths red and black
Some reckon the red is an anti-vampire warning Others say that the red side is for to attract bulls in fields whilst the black side is for hiding behindrobinb wrote:I have 2 dark cloths which are both black and red
Seriously though, I haven't yet found an explanation, apart from to tell which side is the outside (the black). I use a Paramo darkcloth from Light and Land; it is the same black colour all over, apart from the elasticated collar which holds it to the camera; IMO, it is the best darkcloth I have used.
There is also the BlackJacket, which has sleeves and is black on the inside and silver on the outside; very useful for pretending there is a nuclear emergency, thus frightening off people that might get in your shot
I just use a fleece sweatshirt which is black all over. I suppose I could always buy a red one and sew the two together....
You use the ground glass!? Wusses!!! If an external viewfinder is good enough for them Leica folk, I should be able to get away with 4x5 cardboard cut out... The equation for bellows length to focal distance is hardly rocket science and according to Joanne, you only need to stick 0.25 degree of tilt on for any shot you want!Joanna Carter wrote:Some reckon the red is an anti-vampire warning Others say that the red side is for to attract bulls in fields whilst the black side is for hiding behindrobinb wrote:I have 2 dark cloths which are both black and red
Tim Parkin
Northern Photographer
p.s. I'm working on just waving the film at the scene but things aren't going well at the moment (which probably explains the pictures I got back from Eigg)
Now, if you're going to throw insultations at folks, at least get the the degree of insult right, it's 0.0006° of tilttimparkin wrote:You use the ground glass!? Wusses!!! If an external viewfinder is good enough for them Leica folk, I should be able to get away with 4x5 cardboard cut out... The equation for bellows length to focal distance is hardly rocket science and according to Joanne, you only need to stick 0.25 degree of tilt on for any shot you want!
Don't shout too loud about that, otherwise I won't get to sell any of my film envelopestimparkin wrote:p.s. I'm working on just waving the film at the scene but things aren't going well at the moment (which probably explains the pictures I got back from Eigg)
Joanna, may I ask what is the evidence for your contention regarding the orientation of the colours of the hallowed British darkcloth?Joanna Carter wrote:the outside (the black)
George
Well, if they were yellow and black you might get problems with wasps.
No evidence to offer apart from simple good taste and an innate sense of fashionGeorge Hart wrote:Joanna, may I ask what is the evidence for your contention regarding the orientation of the colours of the hallowed British darkcloth?
A large piece of dark green velvet is also nice when it gets colder. I used green velvet years ago with my old MPP camera, as the metal blades were not too effective with its poor (compared to Ebony) GG. Having said that, with a Maxwell screen in well lit conditions, unless you are using a wide-angle or macro lens, you dont need a dark cloth at all!
The red cloths are red because, like pirates being called pirates, they aaaaarrrrrre..... ...but they might be red to warn passing members of the public that there is a person behind the dark cloth with an eccentric hobby: large format photography.
The theory that I've heard more than once is that when all film/plates were orthochromatic dark cloths were red lined so that any small light leaks didn't ruin the plate or sheet of film. My wife made me a red lined dark cloth and the red material matches the bellows on my B&J. This prooves that it don't take a lot to keep an idiot happy!
Vanman
Vanman
One would simply resemble a hoverfly.... It might warn curious onlookers off! I could certainly see advantages in owning such a darkcloth!Patrick Dixon wrote:Well, if they were yellow and black you might get problems with wasps.
I used to have a two sided one that was very dark blue and white. But it weighed a ton(ne). Now mine's dark green - for camouflage.
