Post
								by scovell001 » Sat Feb 13, 2010 11:21 pm Etc/GMT-1+01:00
			hello Charles,
I'm trying to respond to your post without sounding condescending, so apologies if I do.
Its very easy to get tonal values (o-255) confused with colour gamut. The histogram shows the distribution of tones within an image on a scale where 0= pure black & 255= pure white (I'm sure you already know this). It doesn't show the gamut (colour volume) that the device (camera/scanner) can capture. When you see the histogram on a digital camera display, its showing you how the CCD has recorded certain values. For example, you can see a brighter white than a digicam cdd. But the ccd can only cover a certain dynamic range. The ccd records what it thinks is a pure white, (because thats as far as it can see into the highlights) and maps that to 255 (and 0 for black) on the camera histogram. So, you think you've got this a nice full histogram, but in reality full dynamic range has been lost, ie some whites have been clipped & blacks are plugged. In reality, you'd want to have a narrower readout histogram, to ensure a digicam has captured the full dynamics of the scene, similar to that which you are experiencing with your scanning. You can then go and set highlight & shadow (0 & 255) yourself later.
Back to scanning.
In photoshop (and all other software) 0 is pure black, & 255 is pure white (as you already know). But, your Epson scanner can't record a true 0 black natively (I don't there is a scanner that can). So, what your scanner thinks is pure black, is actually around 15-20 (in the case of an Epson) on the 0-255 scale. Your scanner does have excellent highlight dynamics, so again what is a pure white in the negtaive/tran would normally record around the 230-245 mark (unless you've inadvertently clipped the highlights in the scanning software). Therefore, depending on the dynamic range (daytime, nightime etc) of the original neg/tran, this will determine where its tonality sits on the histogram & give you that narrow range in the middle of a 0-255 histogram scale aka - a small lump in the middle of a huge black desert!
The final part would be to stretch that narrow band of information in the middle of the histogram so it fills the full histogram bar. You can do that simply by setting highlight & shadow in levels, in Photoshop. Hold down the alt key and drag each of the highlight and shadow sliders in until they meet the edges of the histogram but don't clip any colours. Hit OK, and now look at the histogram bar. You'll see that the histogram is now full from 0-255.
So, to summarise. There is no way to set which brightness levels your scanner scans. It will just record what it thinks is pure black and pure white (and all in between) to a histogram which illustrates black as 0 and white as 255. Its up to you to adjust the highlight & shadow to map the image to the full width of the histogram display.
Hope this helps
