* http://www.youtube.com/watch?v=Sr57E22E ... re=channel
** http://www.youtube.com/watch?v=dDBIOkPYHqo
I do actually fancy the Arca Swiss C-1 cube***...... but the price!
*** http://www.youtube.com/watch?v=FU0ovTGw ... re=related
The BH55 is very good and stable but does move slightly when you lock it up (very slightly but with Macro I could imagine that would be annoying). The people I know who use 410's have all complained about the mechanism getting 'loose' over time (Joe has replaced his multiple times and now uses BH's and Acratechs, Dav Thomas is looking at the PhotoClam) .. however it might be cheaper to replace the 410 multiple times than buy a C1Thingy wrote:I need to get a more manovrable head for macro photography using my 45SU and was wondering what people would recommend? I have looked at the YouTube demos of the Z1* and the BH-55** and am not sure. If I go down this path I would also really like to buy a head to replace my current Manfrotto 410 for landscape work, and would like to know if monoballs are versatile, stable and robust enough for using with my Ebony 45SU and lenses such as the Nikkor 90/f4.5 and Cooke PS945? Does anyone have experience of using monoballs for LF photography?
I do actually fancy the Arca Swiss C-1 cube***...... but the price!![]()
Relative weights for the systemsPAUL O wrote:I've tried a variety of heads over the years with LF - both pan/tilt and ball-types. I've tried the Manfrotto 410 amongst others and it is okay but I replaced it with an Arca Swiss B2 and haven't looked back! The AS is a bit heavier but a lovely piece of kit! It uses an aspherical ballhead design with an inner and outer ball that lock and move independently of each other so very much like a pan/tilt type. All movements are friction controlled and the movements are super-smooth. For the 45SU the 410 should be fine or you might consider the larger 405?
Those weights are soooooo useful.timparkin wrote:Relative weights for the systemsPAUL O wrote:I've tried a variety of heads over the years with LF - both pan/tilt and ball-types. I've tried the Manfrotto 410 amongst others and it is okay but I replaced it with an Arca Swiss B2 and haven't looked back! The AS is a bit heavier but a lovely piece of kit! It uses an aspherical ballhead design with an inner and outer ball that lock and move independently of each other so very much like a pan/tilt type. All movements are friction controlled and the movements are super-smooth. For the 45SU the 410 should be fine or you might consider the larger 405?
405 - 1600g
410 - 1220g
Photoclam - 950g
ARCA C1 - 925g
BH55 - 815g
BH40 - 479g
Acratech ultimate - 450g
The Acratech is more than capable of holding a 45SU
How are you getting on with the GV2? Does it clamp tight enough to support your 45SU? Any update would be appreciated.Thingy wrote:I will do. I've used it a little to do some indoor still life images and was pleasantly suprised how easy it was to level the camera. With the 45SU the tension for the ball head needs to be set almost to the limit but having set the tension, which was quick and easy, levelling was quicker. I should also add that another factor for me is that turning the relativly stiff knobs of the Manfrotto 410 can on occassions be difficult. If you're not arthritic then objectivly I would broadly agree with Joanna, that the fine movements of the 410, on a tripod where all the legs are of equal length, the 410 is excellent. When your tripod legs are at different heights I think the GV2 is considerably easier to use. The best was is to try one out. I also appreciate the fact that the GV2 weighs around a third what the 410 weighed.
