HI
Does image circle get bigger the closer you focus
i.e. if you have 250mm when stopped down at f16 at infinity will you get a bigger image circle if filling the frame with a head shot
If so  how would I work this out ?
thanks
Robin
Re: Does image circle get bigger the closer you focus
It does absolutely get bigger. If you know what an image circle is at infinity at a particular aperture, you can work out the image circle at any extension with simple trigonometry.
twice as big when you've got something life size on your screen!
