Page 1 of 1
Then and Now pictures - advice needed
Posted: Mon Jun 20, 2011 7:48 pm Etc/GMT-1+01:00
by Matt_Bigwood
I'm planning on doing a 'then and now' series of photos, trying to do modern versions as close as possible to the photos of Murray Dowding, a commercial photographer who was active between about 1910 and 1930 in Chipping Sodbury and the surrounding areas north of Bristol:
http://britishphotohistory.ning.com/pro ... -of-murray
I've had access to his glass plates, most of which are half-plate 6.5inch x 4.25inch, although there are a few 10x8 inch plates. I'm guessing he would have taken everything with a standard lens - on some of the quarter plates there's evidence of vignetting and the lens running out of coverage when he's used a fair amount of front rise.
Would moderately wide or true wide angle lenses have been in common use in those days?
Re: Then and Now pictures - advice needed
Posted: Mon Jun 20, 2011 10:12 pm Etc/GMT-1+01:00
by Neil Barnes
'Standard' lenses would have been, I think, slightly wide angle by modern standards. Only prime lenses were common. At the time, either RR (rapid rectilinear) or Anastigmats were the best lenses available, probably with a focal length not too much shorter than the diagonal of the plate.
I have 10.5cm lenses intended for 6*9cm roll film, 13.5cm for 4*5, 11.0cm for 5*7, and 13cm for quarter plate - all of about that vintage.
Posted: Mon Jun 20, 2011 10:37 pm Etc/GMT-1+01:00
by Neil Barnes
Some calculated included angles on the diagonal - only the 110 on the 5x7 would be considered wide angle these days.
Code: Select all
Lens Film Diagonal Angle
105 6x9 108 45.8
135 4x5 160 49.8
110 5x7 215 62.9
130 qpl 116 41.2
Posted: Mon Jun 20, 2011 11:20 pm Etc/GMT-1+01:00
by Joanna Carter
We did a similar exercise in a village in France last year. They had a load of prints of old postcards around the square; we took digis on a Canon G10 and then walked around looking at the LCD screen until things lined up. We usually found ourselves using the 90mm f/5.6 Rodenstock or the 120mm f/8 Nikkor to match the point of view and angle.
Posted: Tue Jun 21, 2011 6:43 am Etc/GMT-1+01:00
by Matt_Bigwood
Thanks for the information - I hadn't really considered that wide-ish lenses would have been all that common in those days.
I've got a couple of books about old cameras, and whilst they list manufacturers and types of lenses there's not any info about what equipment was in use at the time.
Posted: Tue Jun 21, 2011 7:24 am Etc/GMT-1+01:00
by Neil Barnes
Looking at the adverts I found from 1923 (here:
viewtopic.php?f=3&t=2689 ) it's curious that while the maker, type, and f-stop of the lenses supplier with the cameras are all specified, there's no mention of focal length. But I don't think there's been much difference over the the years from the pseudo-standard of focal length approximating the film diagonal.
Posted: Wed Jun 22, 2011 12:45 pm Etc/GMT-1+01:00
by Justin
Neil Barnes wrote:Looking at the adverts I found from 1923 (here:
The catalogues usually have focal lengths as well as coverage eg
http://www.cameraeccentric.com/info.html half plate would be 5-8 inches looking at some examples. I think the earlier you look the longer the lenses are.
Posted: Wed Jun 22, 2011 5:14 pm Etc/GMT-1+01:00
by Patrick Dixon
Is this one of his?
(Sorry about the crappy scan).
The Gatehouse was moved to Berkeley Castle, but the Barn is still here!
Posted: Wed Jun 22, 2011 5:32 pm Etc/GMT-1+01:00
by Matt_Bigwood
Hi Patrick, yes it is a Dowding picture, and I scanned the original plate a month or two ago, along with 300 others that are owned by The Gazette in Dursley. That's what started me thinking about this project.
There are several of theis with captions like 'The ruins of Yate Court, once home to the Berkeleys.'
Do you know where the ruins are/were?
Matt
Posted: Wed Jun 22, 2011 7:01 pm Etc/GMT-1+01:00
by Patrick Dixon
Yeah - we're living in them.
Posted: Wed Jun 22, 2011 7:15 pm Etc/GMT-1+01:00
by Matt_Bigwood
Give me a clue....
Posted: Thu Jun 23, 2011 8:26 am Etc/GMT-1+01:00
by Patrick Dixon
http://maps.google.co.uk/maps?q=bs37+7q ... k&t=h&z=18
(Perhaps I should also say that the drive and the property is private, although there is a public footpath that runs past. If you want to drive up and look, then just get in touch.)
