square wood box
pin hole in the 'front' side
mirror internally at 45deg
opaque perspex (ground glass effectively) top
the idea being you point it at your subject, stick a bit of paper on the top and a dark cloth over your head and you can copy the scene onto your paper. it has to be quite portable.
I guess the internal optical length will be about 20-30cm so I'm looking for a cheap lens in that kind of length to substitute for the pin hole to give me a brighter image.
any suggestions, the budget is very limited, they are moaning at £10 for the mirror
any help or suggestions?
