Shutter Values on lens
Nick Coombs
Post by Nick Coombs » Mon Oct 03, 2011 12:17 pm Etc/GMT-1+01:00
Hi...
I hope this is not a silly question to ask, but here goes.
The shutter speed values on LF lens are these the same ratings as you would see on a moden DSLR.
500 = 1/500 and 10 = 1/10 and 1 = 1sec etc...
I have timed some of my lower numbers on my Camera and if what I think is right as above then mine way out.
Example 10 = a few seconds on mine..
IanG
Re: Shutter Values on lens
Post by IanG » Mon Oct 03, 2011 1:02 pm Etc/GMT-1+01:00
They are the reciprocal values as you've assumed.
It's not unsusual for the slower speeds to get sticky and slow with leaf shutters like Copal/Compur etc, that tends to mean they need a CLA (Clean, Lubricate, re-Assembly). Sometimes a quick flush clean with alcohol or lighter fuel is sufficient (needs to be pure IPA), often the lubricants have gone solid.
Nick Coombs
Post by Nick Coombs » Mon Oct 03, 2011 1:06 pm Etc/GMT-1+01:00
Thanks Ian...
Nick Coombs
Post by Nick Coombs » Tue Oct 04, 2011 8:58 pm Etc/GMT-1+01:00
Ian...
Thanks for the tip, all working fine after a good clean...
Post by dave_whatever » Tue Oct 04, 2011 9:08 pm Etc/GMT-1+01:00
IanG wrote:(needs to be pure IPA)
Have you got any thoughts on brands Ian - which is more suitable for a shutter, something fairly mainstream, like Deuchars or maybe something a bit more local? :wink:
IanG
Post by IanG » Tue Oct 04, 2011 10:25 pm Etc/GMT-1+01:00
The flush clean has resurrected at least a dozen shutters for me over the years, in fact all my older Compur's are more accurate than my newer Copal's but then they are far btter made :D Even my 1913 Dial set Compur works well.
I keep the hoppy IPA for more useful purposes :D and they are great for cooking as well.
Post by Emmanuel Bigler » Wed Oct 05, 2011 11:55 am Etc/GMT-1+01:00
Some shutters of the pre-1960 era have a "non standard" series of speeds : 1/2 - 1/5 - 1/10 - 1/25 - 1/50 - 1/100 - 1/200 - 1/400
(at least, at the time THIS series was the standard ;) )
You can download here
http://farm1.static.flickr.com/128/412475261_57e8f77071_b.jpg
a simple home-made chart that will give you at a glance the nearest values in terms of 1/3-rd of f-stop, if your exposure meter (a youngster) insists on saying : "1/2 - 1/4 - 1/8 - 1/15 - 1/30 - 1/60 - 1/125 - 1/250 ..."
Justin
Post by Justin » Wed Oct 05, 2011 12:35 pm Etc/GMT-1+01:00
Can anyone recommend anyone in the UK for a CLA - I have a 100 year old Regno shutter that doesnt close properly if it is in a bad mood, and I suspect it might need more than IPA to cure it...
IanG
Post by IanG » Wed Oct 05, 2011 7:05 pm Etc/GMT-1+01:00
You could try Ellis & Newton in Liverpool for the repair, I use Black on White in Bristol but not sure whether John there is into really vintage shutters.
I like my older shutters and their speeds are on my light meters :D In fact a selling point was they could be set to speeds in between the markings, a Leica advert for the new IIIa (1936) reminded me as you can do the same with mechanical FP shutter.
Post by Andrew Plume » Thu Oct 06, 2011 5:50 pm Etc/GMT-1+01:00
You're pretty well spot on with BonW - he's not really the right person for vintage shutters and from my conversations with him, I feel that he would definitely endorse that
and not wishing to seem overly smart, (which isn't the point at all) it's Newton Ellis and here's the link http://www.newtonellis.com/
best
andrew :)
Justin
Post by Justin » Thu Oct 06, 2011 7:28 pm Etc/GMT-1+01:00
Andrew Plume wrote:Ian
best
andrew :)
Thanks, I contacted them and they were happy to work on it, will send it off...
