Julian Elliott
Post
by Julian Elliott » Fri Sep 07, 2012 8:39 am Etc/GMT-1+01:00
Morning all
I'm thinking of trying out some black & white film instead of the usual choice of Velvia. however, I know nothing in regards to this type of film.
With Velvia, the use of grads is a must of you're a landscaper and need to control those highlights in the sky. When it comes to B&W though is it the same story?
Jools
Post
by dennis » Fri Sep 07, 2012 8:47 am Etc/GMT-1+01:00
Julian,
I personally don't think that filters are so useful for B & W film since it generally has wider latitude & skies can be burned in at the printing stage if you use 'proper' printing. Filters for me are just another thing to remember/decide on so I just have a haze filter and make up the rest as I go along - seems to work for me. Dennis.
michaelfinch
Post
by michaelfinch » Fri Sep 07, 2012 9:05 am Etc/GMT-1+01:00
I agree. I've used a lot of B&W and never used grads. However, green/yellow/orange filters made specifically for B&W film are very useful for increasing contrast (e.g in skies) or shifting tonal values in conventional film. I find they are less useful with the likes of Ilford XP which also has the advantage of scanning very nicely. I'm sure the same will hold true for similar films from other manufacturers. Hope this helps.
Post
by dave_whatever » Fri Sep 07, 2012 12:50 pm Etc/GMT-1+01:00
If you're used to using velvia with up to 5 stops of grad then you'll find that on b&w film its within the usual range. In extremes they still might give you an easier to scan neg though.
Julian Elliott
Post
by Julian Elliott » Mon Sep 10, 2012 3:36 pm Etc/GMT-1+01:00
Thanks for the replies so far. Seems a bit of a mixed bag!
Another dumb question to add into this. Is B&W film like colour. You have the slide ones and the negative ones?
In a few weeks, I'm off to the Lakes as well as into Scotland if I can. If I can get away with it weight wise I wouldn't mind taking up some film instead of doing just digital.
Post
by dave_whatever » Mon Sep 10, 2012 5:07 pm Etc/GMT-1+01:00
Nah, black&white is all neg film. There used to be a slide film mage by agfa years ago, not sure if it was ever made in large format.
There are ways of processing black&white neg film to give positive transparencies but it sounds like a ballache.
michaelfinch
Post
by michaelfinch » Mon Sep 10, 2012 5:09 pm Etc/GMT-1+01:00
You're absolutely right Dave - but I've never seen it spelt like that!
Post
by timparkin » Mon Sep 10, 2012 9:24 pm Etc/GMT-1+01:00
If I knew I wanted to burn in a sky I think I might use a grad because otherwise you can get a lot more grain which might not be what you want (although it might).
I use grads on neg now and again even though it has even more dynamic range than B&W
Post
by Charles Twist » Wed Sep 12, 2012 5:49 pm Etc/GMT-1+01:00
Hello Tim,
Ever tried the B&W thing of reducing the dev time (pulling) to bring the highlights in to a manageable area?
Post
by timparkin » Wed Sep 12, 2012 7:02 pm Etc/GMT-1+01:00
Charles Twist wrote:Hello Tim,
Yes but typically it's still grainy because it's the increase in contrast that causes the grain rather than the overall brightness. If you use N-1 or N-2 then you'll have to increase contrast across the whole image.
Post
by Charles Twist » Thu Sep 13, 2012 9:02 am Etc/GMT-1+01:00
I am not sure if you refer to contrast modulation as a result of dev or post-processing. N-1 or N-2 reduces the overall contrast of the image by making the highlights less bright, but the shadows and mid-tones are relatively unaffected by pulling (in my experience of B&W). The highlights are brought in to scanner range. So yes, there is still an increase of grain in the highlights, because highlights are highlights after all and post-scanning processing to retrieve detail from this kind of area does increase contrast. But the bulk of the picture dosn't suffer in my experience (unless you don't mask and use the same post-processing all over the image).
Post
by timparkin » Thu Sep 13, 2012 9:25 am Etc/GMT-1+01:00
Charles Twist wrote:I am not sure if you refer to contrast modulation as a result of dev or post-processing. N-1 or N-2 reduces the overall contrast of the image by making the highlights less bright, but the shadows and mid-tones are relatively unaffected by pulling (in my experience of B&W). The highlights are brought in to scanner range. So yes, there is still an increase of grain in the highlights, because highlights are highlights after all and post-scanning processing to retrieve detail from this kind of area does increase contrast. But the bulk of the picture dosn't suffer in my experience (unless you don't mask and use the same post-processing all over the image).
Hi Charles
All of the tones are affected when pulling.. see the sensitometry curves in the following post
http://theonlinephotographer.typepad.co ... davis.html
Julian Elliott
Post
by Julian Elliott » Thu Sep 13, 2012 7:27 pm Etc/GMT-1+01:00
Interesting discussion from my original request!
From the looks of things it seems to be that using a grad on B&W wouldn't hurt at all and in the end is probably more beneficial than trying to faff around in the darkroom. In a way, it's almost like those that foul things up digitally and just try to recover in PS or LR etc.
How about reciprocity failure? Does this come into B&W film? And what ISO 50 films are out there?
Post
by timparkin » Thu Sep 13, 2012 8:10 pm Etc/GMT-1+01:00
Julian Elliott wrote:Interesting discussion from my original request!
Reciprocity will affect some films
http://home.earthlink.net/~kitathome/Lu ... rocity.htm
Reciprocity also makes pictures more contrasty as it only affects the darker areas of an image and it makes them even darker.
Post
by dave_whatever » Thu Sep 13, 2012 9:07 pm Etc/GMT-1+01:00
One of the big shockers for me after using Velvia was shooting some FP4+ and realising from the datasheet that the reciprocity failure quoted for ilford film is actually worse than Velvia!
