Let me start by saying that this is not a personal attack on Joe Cornish whose work I both admire and sometimes envy; it is meant to be a reasoned discussion of a technique that some people seem to have (slavishly) followed, possibly, simply "because Joe does it"
What is the point of asymmetric movements on the rear standard of a camera?
As far as I can see, the reasoning is that, by placing something in your prospective image on one of the "third" lines, one is able to focus that point and then simply apply a single movement to bring everything else into focus.
So, how about architectural work where the rear standard has to be totally upright to avoid converging verticals? The answer seems to be to apply rear tilts, using the asymmetrics, and then "transfer" the movement achieved to the front standard. Now, I can understand that this kind of thing is possible on a studio camera like a Sinar, which has precision movements with graduated scales but, on an Ebony???
Now, to come to landscape photography, which seems to be the majority interest, and in regard to that which John (FearZeus) wants to move into...
I can see utility in using asymmetric movements if one wants to take Joe Cornish "signature" images with a large rock in the forground and a disappearing beach in the background, where adding a bit of rear tilt will exaggerate the perspective but, what of those images that do not conform to that stereotype?
I take images like this where the hingepoint is set, something like, 30ft above the camera and the plane of focus passes through the gutter of the nearest house on the right and ends up through a streetlight at the bottom of the steps. There simply wasn't any "quick fix" where something was on a third; what is more, the architectural content precluded the use of rear movements. And, no, simple depth of field focusing wasn't an option here.
Or an image like this where, once again, the plane of focus had to pass, for most of the image, through thin air, in order to get things like the edge of the wharf in the foreground in focus.
Surely, asymmetric movements, if provided, would be better placed on the front standard so that, if they have utility for a given image, there is no need to "transfer" such movements.
If exaggeration of perspective, where a rock is in the foreground, is the desired aim, then why not simply move the camera closer to the rock?
I suppose that one could argue that, since the asymmetric movements place lines on the thirds of the screen, is this not really just a gimmick to "prompt" a photographer to place a compositional element on the third, thus making the picture more aeshetically pleasing without as much thought on the photographer's part?
Could the provision of asymmetric movements and "third" lines on the focusing screen tend to lead us to making "formulaic" images rather than looking for compositions that break the "rules" but which are still visually attractive?
If you don't want to be "coerced" into taking formulaic images, prompted by the way that you focus, is there truly a need to spend more money than is otherwise necessary to obtain a camera?
Why buy an Ebony 45SU when a 45S will do the same job?
Why buy an Ebony SV45U2 when a SV45Te will do the same job?
And would another, little known, design peculiarity not achieve a similar effect? All Ebony lens boards have the lens hole offset vertically, thus making the axis tilt on the front standard behave asymmetrically.
So, in summary, are asymmetric movements really a financially worthwhile gadget, or simply a financially unnecessary gimmick?
I await your comments
