Post
by Paul Mitchell » Sun Feb 01, 2009 11:14 am Etc/GMT-1+01:00
I have a bit of a numpty question to ask... I have just bought a very nice Schneider 240mm f9 G-Claron and am trying to attach it to the lens panel. When I attempt to tighten the rear retaining ring with the wrench I cannot move the aperture ring at the front, it seems as though there should be something to create a small space between the front of the panel and the aperture ring enabling it to move freely. Have looked at one of my other lenses and there's a small pin creating a gap. There doesn't seem to be one on this lens. Am I just tightening the ring too much? Any advice would be gratefully received.
Best regards
IanG
Post
by IanG » Sun Feb 01, 2009 11:58 am Etc/GMT-1+01:00
The pin is just a locating pin to keep the lens orientated on some boards. It isn't normal to need a spacer if the board's cut to the right size. None of my lenses has one.
You might be over tightening, or the hole is oversize so your pinching the aperture control.
Bip
Post
by Bip » Sun Mar 01, 2009 8:17 pm Etc/GMT-1+01:00
Might help, in case its this type of issue... i had a couple of sinar boards of varying ize and a couple of lenses to fit... i went to a machinist and asked him to sort it... very precise workers in metal, and i can interchange lens barrels when i like...
Bip
Steve Nicholls
Post
by Steve Nicholls » Mon Mar 02, 2009 12:46 am Etc/GMT-1+01:00
Paul cut a cardboard washer just smaller than the fixed circular section that is inside the aperture mechanism on the base of the lens between the lens and the lensboard and that should give enough clearance.
Steve
