Interior photography
Hi
For those of you with experience of shooting interiors on 5x4, is a 90mm wide enough for most occasions?
thanks
Bip
thanks
Bip
Apple
Hi Bip,
I've got the 90XL but for an odd picture it hasn't been wide enough. I've also got the Grandagon 75m f/6.8 which is a last chance desperation measure as it has very limited movements - the 72XL is a lot better in this respect and would be a good next purchase for me if the money was available.
There's always the 47XL and 58XL lenses...
Apple
What's wide on a 4x5 will not be as wide on a 6x9 so for the same field of view, you'd need even wider but you'll have more movements...
I originally bought 75 and 210 to use with a roll film back as it would give me a lot of movements but once I'd tried 4x5 I didn't go back
It's an old picture but this was taken with the 90XL inside Wells Cathedral - it depends how big your interior and how much you want to get in as to how wide you need to go - stating the obvious but what's suitable for a cathedral might not be right for a picture of a house bathroom (unless it's palatial
Apple
I can't say much about Rodenstock range apart from they have a very nice 90mm f4.5 version. For Schneider, the XL is the wonder lens, the f/8 is decent but it's a stop slower if working inside dingy interiors. I'd avoid the f/6.8 lens as this just manages to cover 4x5 when at f/22 so no movements possible except on 6x9 and also, they're an old lens so might not be as contrasty / punchy as modern ones.
Peter Walnes is selling a secondhand Schneider SA 72XL on ebay for £889 + £7.75 p+p (in a Prontor Professional 01S shutter), as against the current price of over £1600 new!!!Apple wrote:Hi Bip,
http://cgi.ebay.co.uk/72mm-f5-6-Schneid ... 240%3A1318
Having said that, I bought my 58XL from Robert White (ex demo) and centre filter (new) for less than the 72XL... which with CF is a HUGE lens!
Apple
That's an eyewatering set of prices and I'm not likely to be going for it soon - the £889 is similar to the new price of recent (sensible) times. I can understand the £1075 for a standard lens but the other prices are a joke - I guess they mean the 'new' price is RRP.
I've not used a centre filter on the 90mm and Joanna hasn't used one on the 72 AFAIK so unless it's critical, I'd try without first...
Hello Bip and co.,
With a Schneider 75mm f/5.6 (a good alternative to the 72XL for the price, I reckon), I have no appreciable fall-off problems - less than 1/3 stop? The general wisdom seems to be that centre filters are only really useful if you're photographing uniformly lit subjects.
Bip: I would check out the image circle of the W lens. There is the W and the SW: I suspect the latter has far more coverage. Depends what elbow room you need...
Andrew's shot shows how much width you get with a 90mm. The vaults are made to look even more soaring. Bring that into a small room with furniture, and suddenly you end up with very long table legs and big, empty picture spaces not always doing very much. Again depends what you need...
FWIW, in a small room I find a 90mm and a 120mm handy for giving context, and a 210mm handy for picking off detail.
I hope that helps.
I hope that helps.
Totally agreed. I have not found it worth the money for the CF and have not found it necessary. See this image :Apple wrote:I've not used a centre filter on the 90mm and Joanna hasn't used one on the 72 AFAIK so unless it's critical, I'd try without first...Andrew
Thanks to you all.
I'll continue to hunt for a 75mm / 90mm lens and see what happens. There are numerous 90mm f8 but i suspect i'l have trouble focusing them. I'm not looking for top of the range. And for a4 repro i don't think i need to buy a £1,000 lens.
Good to read everyones opinions.
Onwards
Bip
Onwards
Bip
I would definitely recommend you stay away from f/8 lenses for interior work. The above image was taken in very low light conditions with a colour temperature of 2300° and was not easy to see some parts using the Schneider 72mm f/5.6 Super Angulon XL.Bip wrote:There are numerous 90mm f8 but i suspect i'l have trouble focusing them.
Just to give you some idea of the coverage of the 72mm, the brass knob and start of bannister rail in the bottom left of the image was only about 4-5ft in front of the lens; the camera was positioned on the staircase.
