Two good, two bad
Two good, two bad
Hi All
I haven't been around here much over the past couple of years, but I do visit without automatically logging in all the time, so I haven't been ignoring you all either! I've come to the conclusion that one of the reasons I haven't been doing LF recently is that I'm not getting the buzz when using my camera (don't ask!),so maybe it's time to change it. Problem is that I'm not in a position to play with any other cameras, so must rely on what others say about theirs.
I've searched the Forum without finding this type of question, so I'd now be grateful for anyone's 2 good/2 bad experiences, by which I mean the 2 best things about your current camera and the 2 worst bits about your previous one that made you want to change it. This will obviously include little things that can be infuriating, so feel free to let rip!
Many thanks, Peter
Many thanks, Peter
Hello Peter and welcome back!
I like your post - could be very useful. So I'll provide a start, even though I have experience of only camera, a Toyo 45A.
Pros:
(i) built like a tank but not overly heavy; survives life on the road in my back-pack (no mean feat); rigid when set up (no vibration)
(ii) a good set of movements for the price: tilt and swing on both standards, plus vertical shift on the front
Cons:
(i) no spirit levels
(ii) no dedicated lateral shift (have to use opposing swings)
I look forward to hearing the other reports. What's wrong with your own camera?
Pros:
Cons:
Thanks Charles, that was useful. There is absolutely nothing wrong with my present camera as such, it is just that it doesn't quite suit me, for whatever reason!
It's a bit like the Nikon/Canon debates you see elsewhere and I always thought they were meaningless trivia, until I changed from Nikon to Canon and found there was a different feel to the handling and use. Now there is absolutely nothing wrong with the Canon, but 2 years later I still don't find it intuitive to use compared to the Nikon. Maybe it's just me!
Ebony 45SU.
Good points:
1) Build quality
2) Asymmetric tilts
Bad points:
1) Locking knobs on other side of camera from focussing knobs. It's really irritating to have to change hands to lock everything off.
2) When replacing the bellows it's possible to think they are locked-in and light-tight when they're not. Wasted 10 sheets of QL before I had that one figured out.
Good points:
1) Build quality
2) Asymmetric tilts
Bad points:
Re: Two good, two bad
Tut, tutPeter B wrote:I haven't been around here much over the past couple of years, but I do visit without automatically logging in all the time
Which is one very good reason to participate on these fora; and to join us on one of our workshops. Next one is in Maldon, Essex; I know it's a long way but quite a few "southern softies" made the trip to GlencoePeter B wrote:I've come to the conclusion that one of the reasons I haven't been doing LF recently is that I'm not getting the buzz when using my camera (don't ask!),so maybe it's time to change it. Problem is that I'm not in a position to play with any other cameras, so must rely on what others say about theirs
Joanna, it is one of my regrets that I didn't make it to the Glencoe bash, since there was also an ephotozine weekend at Rowardennan at the end of that week. To have had a week's LF immersion and take it in amongst the epz digi fiends would have been great, but alas it never happened.
Jools, since I've mentioned epz you'll possibly recall we had an exchange on there this past week when you were pondering the future of your "spare" camera, so I'll maybe get back to you over the next couple of weeks if you want to think more about it.
Thanks, Peter
Thanks, Peter
Anothyer vote for the Ebony 45SU
Good points:
Asymmetric movements - couldn't live without them!
Range of movements available - everything you'll ever need!
Interchangeable bellows
Bellows extension - from wide to long no problems!
Design of spirit levels - mirror box is a great boon when tripod extended high!
Smell
Bad points:
Current price
Good points:
Smell
Bad points:
Current price
Ebony RSW45 (only LF I have owned)
Good points;
It looks great
Its lighter and quicker than most LF cameras
Bad points;
Occasionally (just occasionally) I wish it had a few more movement options.
It has a short bellows draw but I have found a 270mm lens that works so this is not a big deal.
And this is what JC said about it;
"By now you will have gathered that I didn't like this camera. I absolutely loved it. It is just as beautifully made as its costlier brethren, yet by reducing the specification to the bare necessities, Ebony has made a quality camera that is genuinely affordable. Its simplicity is also an advantage, reducing weight and helping to avoid the problems caused on more complex models when swing and cross movements get 'un-zeroed' by mistake and remain undetected. Simplicity also seems to result in superior rigidity. This is one of those rare objects which genuinely deserves the description 'less is more'. The fact is that if you are a landscape photographer, this is not just the cheapest Ebony you can buy, it may also be the best you'll find."
Good points;
It looks great
Bad points;
Regs, Nigels.
Peter, how about something a little lower down the price scale.
Shen Hao TZ45IIA.
Good points:
- Fairly light
- Good range of movements
- Cheap as chips, but not in build quality, it's a well made bit of kit
- Uses Linhof lens panels and has an international back
Bad points:
- Base tilt
- Not too great with wide angle lenses
This is the only LF camera I've owned, and I've only tried one other, a Linhof TK45 which is a little heavier than the Shen, but is my 'money no object' camera.
Chris.
Shen Hao TZ45IIA.
Good points:
- Fairly light
Bad points:
- Base tilt
Chris.
I have recently aquired a TK45 and so far am very happy with it.
Good Points:
Lots of movement, as good as any trad monorail I have owned/used.
packs well, very clever.
Covers a huge lens range.
Bad Points:
Heavy, close to 3kg, I shoot in the hills alot and it can be quite a burden with 4-5 lenses etc over 15+Km.
Expensive accesories, branded at least.
It was my "money no object" choice too, though I never thought I would own one. You gotta love *bay!!
Good Points:
Bad Points:
