basic error ? help please !
Hello. I would be grateful for some advice as I am new to large format photography. I recently purchased an Ebony SW45 and I am having difficult with a certain type of image.
In the following image I have the whole camera tilted forward at approx 10 degrees and in addition an amount of fall at the front. I use an Ebony wide angle fresnel. There is a small amount of front tilt. I have applied no movements at the back. This particular image was taken with a 150mm lens but still using the wide angle fresnel.
It is not due to light leak as other 2 other portrait images and 2 landscape images have turned out fine.
Under the dark cloth the image seemed fine but obviously the end result isn't - If anyone can shed some light on this - I would be very grateful.
The link to the image is www.rossbrownphotography.co.uk/photo_3737766.html
I know nothing about LF, but it looks like a light leak. Are you sure that that combination of movements is not exposing a leak in the bellows or at the top of the lens board?
You could try setting it up like that and checking for light leaks on the GG with the shutter closed, I guess you wouldn't necessarily see a leak with the shutter open.
I think that I had pushed the film correctly in and out of the quickload holder.
My only other thought now is whether I had correctly fitted the quickload holder snugly into the back of the camera and whether there could have been a light leak at the bottom - between the quickload holder and camera back!
Thank you for your help.
Can I ask whether the film has a black margin, or is the sheet fogged right to the edges?
If it has a margin, then you can suspect the holder not being seated, but I would also expect a slight shadow around the edge of the image where the holder "protected" the film from direct light.
If there is no margin, either you didn't seat the envelope in the clip, or the lab goofed
Hello
I've taken photographs of the transparency
1. left lower edge - www.rossbrownphotography.co.uk/photo_3740279.html
there is a 1mm light grey ?shadow along the base of the image - not present on any other transparencies.
2. left upper edge + top (dots are long the top of transparency). www.rossbrownphotography.co.uk/photo_3740301.html
3. overall - www.rossbrownphotography.co.uk/photo_3740302.html
does that help diagnose the problem ? (or not!)
I can't be sure but this looks like the film was in the holder whilst it was being fogged. See the side edges nearest to the notch appear to be thinner than the rest, indicating that this is where the fogging was strongest.
I would say that, somehow, the holder was not correctly seated under the spring back, allowing the front of the bottom of the holder to become separated from the back of the camera.
Yet another "put it down to experience" moment
Yes, it looks like the quickload holder wasn't seated in the camera properly .. Very annoying.. However I do know of someone who went on a whole two week holiday to the states and returned to find out his quickload holder wasn't holding the film bottom when exposing. Lots of unexposed film and a memories only...Joanna Carter wrote:I can't be sure but this looks like the film was in the holder whilst it was being fogged. See the side edges nearest to the notch appear to be thinner than the rest, indicating that this is where the fogging was strongest.
