Joanna Carter wrote:Tim, if you are happy with sending a neg through the post, I would be happy to scan it and post the result, then send you back the file with instructions on how to maximise what's there
If you don't fancy sending the neg, I can arrange an ftp drop on my server where you can send a full range scan.
Hi Joanne - I did send you a pm (or I
thought I did
) regarding sending you the neg but I'm not sure it arrived in your in-tray ? Since I took this I've taken a several more b&w shots - and I think I may have a problem or just not used to neg film. Now Its probably me OR poss. its the developers (Peak) - all my photos are completely flat contrast wise. If I scan 'raw' in Vuescan (which I'm happy to do with E6 tranny and am quite pleased with the results) and set appropriate black and white points - everything is still ultra low contrast.
I've bought an orange filter that I've yet to try but is this the norm for un-filtered B&W ??
PS I can post a negative scan of the following image I quite like if that helps :-
Swanage small pier by
Tim_Hodgson, on Flickr
This has quite a steep contrast enhancing curve applied in Photoshop to get to this point and some processing on the sky - I'd rather get closer in-camera if possible.
thanks in advance tim....
