FS New Copal 0 shutter
Peter B
Re: FS New Copal 0 shutter
Post by Peter B » Sat Jan 09, 2010 12:14 am Etc/GMT-1+01:00
I'm not afraid of the cold, Peter. Better that than the 105 degree F heat we had all summer here. :shock:
I'm no expert on cold Mike, but I understand from another forum that the biggie is the humidity, since dry cold feels warmer/better than damp cold. :?: A quick check on Google gets me Dallas as -3C and 41% humidity, whereas here in Inverness we have 98% humidity to go with our -3C on Sunday. :?
I'm better with heat and can tell you that 105F is possibly beyond my ability to survive! I know that 30C equals 86F and that's about the limit of my comfort zone, although I suppose I could acclimatise if the high temps lasted a while. 105F seems to be about 40/41C, so good luck with that!
Mike1234
Post by Mike1234 » Sat Jan 09, 2010 12:53 am Etc/GMT-1+01:00
Bingo, Peter. Cold is better than hot in my current health condition.
IanG
Post by IanG » Sat Jan 09, 2010 2:59 pm Etc/GMT-1+01:00
robinb wrote:Hi
What dose CLA stand for ?
And where would one get it done ? in England
How accurate should I expect a shutter to be
Robin
Black on White in Bristol have done the last 3 CLA's - Clean, Lubricate, Adjust, for me and the shutters are all accurate now to well within 1/3 stop, I have tested the slower speeds and they are remarkably accurate, I have 80-90 year old Compurs that match modern Copals when tested.
B on W totally disassemble Copal/Compur type shutters clean the parts thoroughly then re-assemble and finally adjust, most UK repairers seem better than US counterparts getting speeds well within tolerance, so you don't get a piece of paper saying that the 1/5 is actually 1/2 etc :shock:
RichardP
Post by RichardP » Sat Jan 09, 2010 4:43 pm Etc/GMT-1+01:00
Ian,
Can I ask how do you test the shutter speeds? I have never had my shutters cleaned and never tested to see if they speeds are accurate, is there a machine or something?
Richard
Post by dave_whatever » Sat Jan 09, 2010 7:12 pm Etc/GMT-1+01:00
If you plug a mic into your pc you can record the sound of the shutter opening and view the file in any wave edit type software to establish the duration. I've done this a couple of times, it works really well.
IanG
Post by IanG » Sat Jan 09, 2010 7:25 pm Etc/GMT-1+01:00
Richard, it's remarkably easy and accurate to test the slow speed, all you need is a microphone and a program like Sound Forge or better still Audacity which is free.
Set the microphone and Audacity to record then cock the shutter and trip it at 1 second, then 1/2, 1/5, 1/10, etc then when you analyse the sound wave you can see the spike where the blades open & then later close, you zoom in and read off the time-line.
Looking at my 1933 Compur it takes less than 1/100th second for the mechanism to open the blade, and a fraction less to close them, but I can accurately measure how long they are open for in between and in my case despite it's age the shutter runs a fraction fast, they normally begin to run slower at they age.
You can hear the speeds here Compur. Accurate is within 15% of the marked speed.
As my most common speeds were generally below 1/30 this is a good test, it certainly tells you when speeds are drifting off. My newer Copal shutters inc very recent Copal 0 are a touch slower but then Copals are not as good as even pre-War Compur's in terms of long term reliability, even my dial-set Compurs are accurate.
RichardP
Post by RichardP » Sat Jan 09, 2010 9:22 pm Etc/GMT-1+01:00
Thank you for the information, I have Audacity and a microphone so will give it a go and check out my lens.
Richard
mpirie
Post by mpirie » Mon Jan 11, 2010 10:02 pm Etc/GMT-1+01:00
[quote="Mike1234"]Bingo, Peter. Cold is better than hot in my current health condition.[/quote
A nice single malt can help with the cold. Either by heating you up or (if you drink enough of it) forgetting about the cold :lol:
Mike
Mike1234
Post by Mike1234 » Mon Jan 11, 2010 10:14 pm Etc/GMT-1+01:00
mpirie wrote:
Mike1234 wrote:Bingo, Peter. Cold is better than hot in my current health condition.
Mike
So true, sir!! However, being a backwards Texan, I prefer a good Tennesee Bourbon. :D
mpirie
Post by mpirie » Mon Jan 11, 2010 10:25 pm Etc/GMT-1+01:00
Well Mike, If you ever make it over to Scotland we can have a great time comparing the two! :lol:
Mike
Mike1234
Post by Mike1234 » Mon Jan 11, 2010 10:41 pm Etc/GMT-1+01:00
mpirie wrote:Well Mike, If you ever make it over to Scotland we can have a great time comparing the two! :lol:
Mike
Sounds great, Mike. Be prepared though... just as our California vinyards invaded French high-class high-dollar wines... our southern whiskies might win you over. :D
