WTB: Jobo paper clip thingy's
Dave Dawson
Post by Dave Dawson » Fri Sep 25, 2009 4:09 pm Etc/GMT-1+01:00
Sorry about the vauge description but I'm not sure what they are called :?
I'm after two or three clips that slide onto the internal rails in a Jobo drum to hold the paper in place....Some are just like a split tube whilst others have wings on. Either would be good.
Cheers Dave
Dave Dawson
Re: WTB: Jobo paper clip thingy's
Post by Dave Dawson » Thu Oct 15, 2009 7:20 pm Etc/GMT-1+01:00
Still looking :shock:
Cheers Dave
Keith Tapscott
Post by Keith Tapscott » Sat Oct 17, 2009 11:46 am Etc/GMT-1+01:00
Try Firstcall Photographic. If they don`t have them in stock, they might be able to order them for you.
If you are using a print drum to process 8x10 sheet-films, I find the non-winged clip holders easier to use.
http://www.firstcall-photographic.co.uk ... /view-all/
Dave Dawson
Post by Dave Dawson » Mon Dec 07, 2009 5:10 pm Etc/GMT-1+01:00
Still required (all avenues failed) :(
Cheers Dave
numnutz
Post by numnutz » Thu Dec 10, 2009 12:18 am Etc/GMT-1+01:00
Try cutting some single core cable (aprox 9.0mm diameter) into a 1½ inch lengths taking out the centre core(s) then cut a slit in the cable with a razor blade or scalpel to fit the rail in the tank. You may have to make the slit slightly wider at the ends to facilitate installation and removal but it worked for me.
Test 'em first
Hope this helps
nn :)
Dave Dawson
Post by Dave Dawson » Thu Dec 10, 2009 4:18 pm Etc/GMT-1+01:00
numnutz wrote:Try cutting some single core cable (aprox 9.0mm diameter) into a 1½ inch lengths taking out the centre core(s) then cut a slit in the cable with a razor blade or scalpel to fit the rail in the tank. You may have to make the slit slightly wider at the ends to facilitate installation and removal but it worked for me.
Test 'em first
Hope this helps
nn :)
You may be num but your not dumb....Thanks for the tip :D
Cheers Dave
