Durst 54 Laborator enlarger with Ilford 500 head and controller with probe + RH Designs Stopclock 500.
The actual enlarger is quite a few years old and the bellows have been repaired at some point but have worked perfectly since I've been using it.
It has full movements which can be used to control distortion and make sure that the enlarger is aligned properly to ensure perfect image sharpness.
Bench standing which prints up to 20x24.
Selling with everything needed to print (apart from lenses),negative carriers for 35mm,6x6,6x7 and 5x4 negs.
It uses a Ilford 500 head with the CPM controller and probe but I upgraded and bought the Stopclock 500 from RH Designs which is a real gem to use.
It can all be dismantled and will fit in the back of a hatchback car but as it is such a bulky item it is collection only from near Plymouth.
£200
SOLD - 5x4 enlarger + Stopclock 500
Last edited by Mike M on Mon Oct 05, 2009 5:50 pm Etc/GMT-1+01:00, edited 1 time in total.
Re: F/S - 5x4 enlarger + Stopclock 500
hiya mike, would you be prepared to sell the stopclock 500 separately? cheers, john
