A Fujinon 250mm f6.3 - a much under-valued lens with a massive image circle that will just cover a sheet of 8x10 film. Makes an ideal longer lens for 5x4 and 5x7 with masses of movement potential and all in a Copal 1 shutter!
This example is in a late, all-black Copal 1 shutter with perrrfect speeds! It features Fuji's Electron Beam Coating and is totally unmarked - barrels,shutter and glass. Glass is absolutely pristine - fitted with a new B+W MRC UV filter (67mm) and comes with Fujinon front and rear caps and mounted to a Linhof/Wista panel.
£350 including Special Delivery!
FS - Fujinon 250mm 6.3
Re: FS - Fujinon 250mm 6.3
Same one I use and can vouch for the superb quality
Thanks Ed! Fuji's are much underrated lenses!
Xmas special ... £300 inc postage
