Enlarger Lamps 75Watt 150Watt. Original Ones
Ray Astley
Hi,if anyone has any of the above Enlarger Lamps knocking around and want to get shut. Let me know, Thanks
Re: Enlarger Lamps 75Watt 150Watt. Original Ones
I may have, I'll check this afternoon/evening as I've a box full of surplus darkroom items in storage. bayonet or screw fit ?
Ray Astley
Hi,thanks for reply, screw fitting if you have. Thanks Ray
RK Photographic have the 75w ones in stock according to their website.
http://www.thedarkroom.co.uk/products_c ... tID=P3/3ES
Appear to be cheaper in Morco! http://www.morco.uk.com/lamps.htm
No luick in the loft storage Ray, they were all Photofloods
However I was sure I had one and there's a 150w ES on my darkroom shelf, doesn't fit any of my enlargers - all colour heads or take small bulbs - my Gnome uses a 12 volt car headlight (very old style).
So let me know where you want it sent and cover the P&P
Ray Astley
Thanks for that Ian,yes I will have the 150watt ES off you.Just let me know how much? Thanks Ray
Will test first then PM
