WTB: Nikkor T 360/500/720mm
Joe Wright
Ideally looking for the full combo but would consider just the 360/500
Joe
Website: http://www.josephwright.co.uk
Twitter: http://www.twitter.com/JoeARWright
Facebook: http://www.facebook.com/JoeARWright
Re: WTB: Nikkor T 360/500/720mm
Badger graphic in USA have a used one listed. Might be worth calling them....
Jenny
Jenny
Joe Wright
Thanks Jenny will do, didn't think to check there...jennym wrote:Badger graphic in USA have a used one listed. Might be worth calling them....
Jenny
Joe
Badger have fwiw, a very good reputation
Good luck
Good luck
Martin Jan Köhler
Hi Joe,
did you find one, or by any chance even two?
(already have a 360T, but am also searching for a 500/720mm to try with the Arca)
Martin
Martin
Martin Jan Köhler
http://www.flickr.com/photos/martinjankoehler
Joe Wright
No luck yet Martin, there was a set in the USA, but the customs / duty made it too expensive. If you come across a set maybe we could work something out, you want the 500/720, I could start with the 360?
Cheers, Joe
Cheers, Joe
Joe
Martin Jan Köhler
Sure!
I'll PM you if I find a set.
The 360T is excellent, BTW!
Martin Jan Köhler
Joe Wright
There's a 500 rear element just gone up for sale on LFPF, UK based,
Joe
Thanks Joe - I've been in touch with Martin about this (he's looking for a mint copy).
Joe Wright
Rare as hen's teeth these things, still trying to get a full set myself, if not just the 360T !Phil wrote:Thanks Joe - I've been in touch with Martin about this (he's looking for a mint copy).
Joe
The Nikkor-T 500mm needs 349.9mm of bellows. It works on a Technika without a top hat but I'm not familiar with the Ebony.
Martin Jan Köhler
Found a 720mm on Ebay!
@Joe: registering a search notification on "Nikkor 720mm rear" did the trick!
Martin Jan Köhler
Joe Wright
Great result Martin. Perseverance pays off!
Joe
Martin Jan Köhler
Indeed
Also got a Fuji 600T f/12 in the meantime ...
I'll test both and perhaps sell the Fuji...
However I suspect that the Fuji will be a bit better ...
Martin Jan Köhler
