selling in good condition
* a Jobo CPE2
* with Lift
* manual
* four bottles 600ml
* four measuring cylinders
* Kaiser precision color thermometer with +/- 0,2 degrees celsius precision
* two roll necks with both wheel systems ("run smoothly wheel" and normal wheel)
... now mounted are the "run smoothly wheels" intended for the 15xx drum system,
but the alternative wheels for the 25xx system are included!
* modular splittable Jobo Drum with two 1530 units and the bottom drum part
with sprocket for lift use
(enables 1x, 4x or 7x 35mm)
* Jobo Drum 2840 with sprocket for lift use
The machine is fully functional, heating and motor are stable.
Cosmetic flaws without influence on the functionality: the label on the lift chips off a bit (see picture).
The plastic frame, which frames the bottles and cylinders has a little crack on one side, but the frame is stable nevertheless.
I've developed over 400 large format transparencies in 4x5" with this device without any problems!
Now that I'm doing 8x10, I've switched over to a CPP2 (to be able to use the Expert Drums).
Now that I think about it, the lift is a CPP2 lift, so potentielly the machine could be used with expert drums anyway ...
But I did not try it yet and I think the motor is not indended to do so...
310 GBP excl shipping.
Martin
Larger Images here:
* CPE2 with lift, bottles, cylinders and 1530er Drumsystem: http://www.martinjankoehler.com/inserat ... C_1443.jpg
http://www.martinjankoehler.com/inserat ... C_1451.jpg
* Drumsystem 1530 zusammengesteckt: http://www.martinjankoehler.com/inserat ... C_1411.jpg
* Drumsystem 1530 zerlegt: http://www.martinjankoehler.com/inserat ... C_1419.jpg
* Drum 2840: [img]http://www.martinjankoehler.com/inserat ... C_1427.jpg
* Manual and replacement wheels: http://www.martinjankoehler.com/inserat ... C_1432.jpg
* Kaiser Thermometer: http://www.martinjankoehler.com/inserat ... C_1435.jpg
