L/F filter holder??
L/F filter holder??
Info on Holder for 5x4 ,no outer threads on lenses,What type required??
:Inspiration and Vision make Great Photographs
Dave Parkin
Re: L/F filter holder??
If there are threads on the inside of the lens then you would be able to use any of the screw in (B and W) or system filters such as Lee or Hitec. Lee also do wide angle adaptors which can help avoid vignettingtombo wrote:Info on Holder for 5x4 ,no outer threads on lenses,What type required??
If there are no filter threads you may be able to get a push on filter holder such as the one supplied by Lee for the 50mil lens on the Bronica GS1, not cheap though
An alternative may be the use of bluetac on the filter itself and this can be stuck to the outside of the lens barrel
Dave
L/ffilter holder
Many Thanks Dave,I will track your info, and see what I can come up with.Kind Regards Tom, G
Ole Tjugen
