Yours Tony
Greetings from foggy Worcestershire
Just Thought I say Hello
Ive owned various cameras since 1975 35mm and medium format Im considering buying a LF kit so I need some pointers
Yours Tony
Yours Tony
Paul Sanders
Don't spend a fortune, it is very easy to rack up a huge bill. Have a good look round ebay and various second hand sites (Robert Whites, calumet and teamwork) read plenty of reviews on the various lf websites.
I went to Whites in the end and bought the entry level Ebony RSW with a 90mm F5.6 lens. This does evrything I need, it has enough movements for landscape work although it does have limited bellows extension so not great for 1:1 close ups. The 90mm is about the equivilent to a 28ishmm - it is fine for pretty much everything I do but just occassionally I would like a bit more width and sometimes just a bit more length! But beggars can't be choosers.
I spent about £1700 in total getting my kit together - but I did buy a new camera with a S/H lens, I could have saved even more with S/H body.
If I can be of any further help please let me know but most of the people on this forum have more experience and idea than I do about lf kit.
joolsb
I went the same route as Paul - Ebony RSW45. It lacks all but the most basic of movements (front rise/fall and front tilt only) but what you do have is enough for most situations. That said, back tilt would be nice. The main advantages of this minimalist approach are weight-saving and simplicity - if you only have limited front movements there is much less to think about and possibly get wrong!
Basically, it's a gerat beginner's camera and you simply can't beat Ebony's legendary craftsmanship...
Lynne Evans
I've been using a Wista for about 4 months and it's great - quick to set up, light to carry and all the movements you need: better than the bottom end Ebonies. The only minor drawback I find is that it has base tilt rather then axis tilt - this makes focusing with tilt a bit more tricky, but eventually I'll get used to it!! Otherwise an excellent buy
Thanks Paul!
alangolding
alangolding
Lynne Evans
