On which note, I’d be grateful for advice on the following exposure issue, as my reading/surfing seems to give different advice. Say I meter a scene and discover that the exposure range between the darkest part I want detail in, and the lightest part I want detail in, is more that the exposure range of the film. Lets assume that the film has a five stop range, and the metered range is six stops. Some things I have read say you should use a 1 stop ND grad to bring the highlights to within the films range, others than a stronger ND grad should be used to bring the lightest part down to the level of the mid tone. Is there a right and wrong way here, or is it just a matter of what you think best matches your vision? Perhaps the second way is used because there is less risk of burnt highlights if your metering is not spot on? Any advice appreciated.
PS. I’m not averse to the odd teashop visit!….
