Clive Gray
Post
by Clive Gray » Tue Sep 28, 2010 7:35 am Etc/GMT-1+01:00
Andrew Plume wrote:Clive Gray wrote:
Clive, I'm assuming you have your 'Ansel Adams pack mule' with you to carry all of this gear............?
If only ....and the Wallabies never co operated either
Sorry for the delay in replying
That isn't quite the same rig but it gives you the idea of the usual transport method.
Mike Carter
Post
by Mike Carter » Fri Feb 04, 2011 9:25 pm Etc/GMT-1+01:00
Mine as I bought it. So far, it's looking like an MPP Mk6 and a half: A Mk6 with some Mk7 additions. International back, mainly. Not entirely sure if the two accessory shoes were DIY additions, or why. Rangefinder no longer attached, though I gather this was an option anyway.
banana_legs
Post
by banana_legs » Sat Feb 05, 2011 11:20 pm Etc/GMT-1+01:00
I meant to post a while ago, but there are pictures of my current 'workhorses' here:
http://www.f295.org/Pinholeforum/forum/ ... 284496262/
I have a half-plate constructed too that just needs some bellows making, and the paper bellows on the baby camera are beginning to be only usable with really wide apertures so that the pinholes do not have too much of an effect! As the weather is set to be dreary for the foreseeable future, it looks like I have some folding to do....
Evan
ajmiller
Post
by ajmiller » Sun Feb 06, 2011 4:54 am Etc/GMT-1+01:00
The reason I've been buying 5x7 DDS recently. I bought this circa.1910 Demaria-Lapierre & Mollier 13x18cm camera with Hermagis Apl. No.5 f=310mm Serie II lens. in Paris in November last year. It has a TP cloth shutter which works like a dream and a flash sync port (not sure if this was original but it fires my small digital flash no problem).
Made a 5x4 reducing back using an old Sinar back then decided I was wasting a lot of the film area so converted the back to take modern 5x7 holders. There's nothing fancy about it, not a lot of movements but there is just something I like about using it that is very enjoyable - and the results are excellent. I want to try and find a 'standard' lens for it as 310 is a bit long so I think something in the region of 210/240 which does mean a bit more work on making a lens board but that's half the fun!
- DLM001.jpg (42.45 KiB) Viewed 12741 times
Tony
IanG
Post
by IanG » Thu Feb 10, 2011 11:17 am Etc/GMT-1+01:00
Tony, does the TP shutter work ? If it doesn't or needs a new shutter cloth PM me.
Nice camera BTW I've nearly bought something similar a couple of times.
ajmiller
Post
by ajmiller » Thu Feb 10, 2011 12:11 pm Etc/GMT-1+01:00
Hi Ian - yes the TP shutter does work ok and the cloth is intact.
The whole camera is in excellent condition
Tony
IanG wrote:Tony, does the TP shutter work ? If it doesn't or needs a new shutter cloth PM me.
Post
by Andrew Plume » Sun Feb 20, 2011 12:58 pm Etc/GMT-1+01:00
Hi Tony
that's a lovely '....1910 Demaria-Lapierre & Mollier 13x18cm camera with Hermagis Apl. No.5 f=310mm Serie II lens....'
which is exactly the type of camera that's made for this thread - yes, as was the case with this type of cameras, the movements are restricted but as far as I'm aware the focus was on portratit and landscape work
If you are intending to pick up a French made lens to continue with the theme, the Boyer apo line of lenses are a possibility - some speak very highly of them, the late Man Ray for one - they crop up on 'the big auction site' from time to time
I've a very similar Parisian built 5x7 too, it c/w a Derogy lens, not as cultish as a Hermagis of course - the rear standard is large enough to support a wp conversion
as you bought it in Paris, I'm hoping that you're not still paying for it
ajmiller
Post
by ajmiller » Mon Feb 21, 2011 12:32 pm Etc/GMT-1+01:00
Thanks Andrew.
My wife, who's French and a good negotiator, managed to barter the seller down by a fair amount - he was left shaking his head, but then I think they all do that - so the price was reasonable. From what I've seen recently on eBay the lens would probably sell for as much as we paid for the lot!
It's a pleasure to use and a 5x7 neg makes an excellent contact print.
Tony
Post
by Andrew Plume » Mon Feb 21, 2011 12:56 pm Etc/GMT-1+01:00
thanks Tony
yes, the value of the lens, you're spot on - those made by Hermagis are fairly 'cultish' and attain very decent prices
'bartering in France' - you have to, they expect nothing else
Post
by Andrew Plume » Tue Dec 25, 2012 3:25 pm Etc/GMT-1+01:00
this thread, imo, needs not only to move again but to be kept alive...........................................
I MUST post some photos of what I'm currently using (or intending to use in 013), none of them are flash, at all, just some decent + users, which I have a soft non-cuddly relationship with:
1930's 5 x 7 Technika, c/w unnamed 4 x 5 reducing back;
5 x 7 KB Canham Wood Field;
Half Plate unnamed British Tailboard, converted to 5 x 7;
13 x 18 French Tailboard; and a
11 x 14/10 x 8 unnamed Field
