HI
Just got a Better scanning variable mount kit but need some fluid
which one should I use
There seems too be ywo choices SXL2001 and SC2001
The SC2001 says its for flatbed scanners where as the SXL2001 dose not
What to buy ?
R
Which Kami Fluid
Re: Which Kami Fluid
You do realise that the Better Scanning mounting station works very well without any fluid?
Start by calibrating it dry (back of film to underside of AN glass), then do some scans at 1200ppi, without any resizing. This will give you a 5x enlargement, possibly with more detail than you need. And it's a lot less messy than fluid mounting.
Hi Robin, 2001 is the one I use.
I use 2001 too
http://www.peaklandscapes.com
Large format landscape workshops in the Peak District:
http://www.largeformatworkshops.co.uk
I just realised I didn't really answer your question as you asked which 2001 – I use SSL 2001, although I use a drum scanner it would be fine with a flat bed I think.
