Well... pretty much one shot out of 6!
Toyo 4x5, developed in Rodinal.
Has anyone tried this paper before ?
Cheers...!
Ilford Positive Paper first result
- Ilfordpositive3web.jpg (76.59 KiB) Viewed 25803 times
Re: Ilford Positive Paper first result
I have seen a very nice portrait done with this paper - an ilford rep showed it to me. He said really you MUST pre flash the paper to get the best out of it - unflashed it is quite contrasty.
Thanks deadpandeadpan wrote:I have seen a very nice portrait done with this paper - an ilford rep showed it to me. He said really you MUST pre flash the paper to get the best out of it - unflashed it is quite contrasty.
When I bought this paper I thought it would be a bit easier to deal with but I guess I was wrong...
A darkroom would certainly help... I don't even own a proper set of trays !
hiya sapata
you can pre flash the paper in camera, if you hold a piece of paper in front of the lens or one of those diffuser filter type things over the lens and give it a bit of exposure then that will do the trick. it will be a trial and error situation but you will get much less contrast.
cheers
john
cheers
john
Thanks for the tip John...monst wrote:hiya sapata
cheers
john
Just got few trays from ebay and now will be a bit more easy to work !
