Opening .dng files in PS
Tom Perkins
Hi, I recently discovered Vuescan which I am now using with my v700 to scan my 5x4, at 2400dpi.
In Vuescan you can save scans as .dng files (which means I can put them through camera raw when I open them in PS and adjust WB etc.).
First time I tried this it worked fine, and I thought ok, I'll have a go properly tomorrow, so I didn't save. Next time it doesn't even try to open it and I get:
"could not complete your request because there is not enough memory (RAM)"
I can still open all other files (PSDs etc).
I have 2gb of ram, about 20gb free on my hd and I'm on XP.
Any ideas whats going on?
Tom.
Tom.
Tom Perkins
Windows uses disk space as virtual memory and Photoshop uses disk space for scratch disks. It has been said that Photoshop can require 5 times the file size to manage your image in memory and it doesn't take much to run out of memory and have to use the disk.
You could be doing yourself a favour if you add the new disk rather then changing to it; and tell Windows to use it for virtual memory and Photoshop to use it for scratch disks. Then you need to move some stuff off the orignal disk so that you leave only programs on that drive and have files on the new one.
On a Windows machine I would typically set up the following partitions :
C: Windows - 16GB
D: Programs - 32GB
E: Files - Anything you've got left
F: Temporary Files 32GB
G: Scratch Files - As much as you can spare, preferably a separate physical disk
....etc
C: Windows - 16GB
D: Programs - 32GB
....etc
Have we really moved forward in the last 10 years? This is a definite flame-bait, but looking at things head-on it strikes me that Win98 worked fine for me (just as well as XP is), and I still use Photoshop 5. A recent demo of CS2 has shown the odd tweak, a few improvements and the great speck-buster, but overall I am surprised just how much P5 offered. The main improvements have been processor speed and memory capacity, ie hardware, which are more than welcome for dealing with large files.
I am just left feeling there is a lot of hype. It's more a comment from me, but if you wish to answer, I'll be happy to read your views.
Tom Perkins
Tom, unless you either have something like DiskImage which will transfer the whole partition in one go, or you really don't mind installng everything from scratch, may I respectfully suggest that adding the second disk and moving just your files, not programs, from the old one will be a lot less hassle and will give you better results, especially if you create more than one partition on the new drive.
Ensuring that your temporary files, virtual memory file and PS scratch disks are on a separate disk from the programs will give you much better performance.
Apart from the noisiness of the old drive, why do you feel you need to move the entire shooting match rather than simply adding a second drive ?
