I had already decided what I wanted and needed out of a camera so straight away that narrowed my choices considerably. After seeing the specs for the Titan XL 4x5 on Mike Walkers website I phoned Mike on the Friday and after a lengthy and very helpful chat I decided that it was the one for me!
Although Mike was busy fulfilling other order commitments my camera was built really quickly and I received it six weeks after I placed the order.
Walker cameras are made out of ABS, which is moulded, matt black/grey in colour and uses stainless steel fittings. One of the benefits for me as a landscape photographer with these materials is that ABS doesn’t expand like wood can in the UK’s rainy climate. The first thing I noticed when I picked it up was how sturdy and rugged it felt.
It weighs 2kg, which is fine for me when I’m hiking.
Being a non-folder it is very quick to set up and use, I can now set up and focus my camera in half the time to when I used my wooden field camera.
To some, the cameras movements may seen restrictive, in fact the rear standard is completely fixed but for me this was another plus point. In the past I had issues with image sharpness. A couple of days ago I took identical images with my old field camera and my Walker, I then printed both negatives and even on 10x8 paper I could see a marked difference in sharpness. I can only put this down to the Walker being made a lot more precisely and having the rear standard completely parallel.
Focusing can be done on both the rear and front standard.
The front standard has rise/fall and swing with axis tilts, which lock tightly, although the front shift is an optional extra but I choose against it.
The camera has bubble levels on the side and top of the rear standard and one on top of the front standard.
The standard bellows has a maximum extension of 190mm and a minimum extension of 47mm. The lens in the pictures is a 90mm f/5.6 Super Angulon and I have had no problems with this lens and the standard bellows although any wider and I think the bag bellows would be a must.
On the rear standard there is an international Grafolk back which unclips at the top to change orientation from landscape to portrait.
The standard screen is a fresnel which gives an extra two stops but Mike didn’t have these in stock so he added a Bosscreen which I think is fantastic at no extra cost. A screen protector is then clipped onto the screen before being packed away.
More pictures and details can be found at www.walkercameras.com
To be honest, I’m like a kid with a new toy at the moment. I really like using this camera, it suites my style of shooting. It hasn’t got that lovely look and smell of a wooden camera but that doesn’t bother me, what is important to me is that I have precise tool which will take great photographs and I don’t think this camera will let me down!
